Home » Audio » Craftsmen » So you want some expensive cone feet?
So you want some expensive cone feet? [message #29709] Fri, 23 December 2005 02:49 Go to next message
I have stored in the junk drawer of my mind an article about using drill presss and sandpaper to make wheels for toys.
I needed an 1 1/2" round cylinder for a knob so I tried it. 80 grit on a sanding block barely made a dent in the Macassar Ebony I tried.
So I got out the belt sander! Vroom, vroom.
With the drill press spinning at 1900 RPM all I had to do was lay the sander on the table (it's sides are right on 90^ to the belt) and lightly hold the running belt against the spinning wood. In about 10 seconds I had a perfectly round cylinder.
After such a good result I tilted the drill press table to 45^ and proceeded to "turn" some cones from Ebony, Padauk and Cocobolo. No problem.
Who needs a lathe?
Re: So you want some expensive cone feet? [message #29710 is a reply to message #29709] Wed, 28 December 2005 20:07 Go to previous message
Any recommendations for a good drill press?
And let's see some pictures!
Previous Topic: is there an equivalent PEM nut for wood?
Next Topic: Conical horn project
Current Time: Fri Apr 26 00:59:00 CDT 2024
