Home » Audio » Craftsmen » Aunti-Poly sent this tip
Aunti-Poly sent this tip [message #29486] Thu, 05 May 2005 03:32 Go to next message
With a die grinder or hacksaw or the teeth of your Alsatian cut off the 1/4-20 and 10-24 sizes Hex drivers from your Hex Keys to make a straight part.
Then the next time you need to remove/replace a woofer or horn chuck one in your cordless and away ya' go!
How I used to hate turning and turning and turning........
Re: Aunti-Poly sent this tip [message #29488 is a reply to message #29486] Thu, 05 May 2005 12:33 Go to previous messageGo to next message
I spent 20 minutes Sunday before mounting those four woofers looking for the hex key I had cut down the last time I had to mount woofers.
So I went into the stash and found out I was down to my last key in that size so rather than cut it, I used it as-is.
I think the right-angle thing has something to do with findability. Sort of like cutting the hair of Sampson, they get invisible without it.
Re: I don't do it for a living anymore, but when I did... [message #29489 is a reply to message #29488] Thu, 05 May 2005 15:21 Go to previous messageGo to next message
...I learned time, once lost, is never repaid. So, I took the time to organise:
That, plus the ubiquitous fishing tackle box.
Wow! [message #29493 is a reply to message #29489] Fri, 06 May 2005 14:42 Go to previous messageGo to next message
That's beautiful! Cleaner and better organized than my house, much less my garage.
Re: Aunti-Poly sent this tip [message #29497 is a reply to message #29486] Mon, 09 May 2005 09:16 Go to previous message
If you look hard, they do make hexkey powerdrill/srewdriver bits. Mine came as part of a set for $10.
If you prefer to do it by hand, I like the hexkeys that come in "swiss-army knife" style. The Stanley sets I have unfolds each key to 270 degrees, where it lock at right angle to the handle.
Previous Topic: A money-saving tip from your Aunti- Poly
Next Topic: Paging Bill Epstein
Current Time: Tue Nov 17 12:55:47 CST 2026
