Home » Audio » Craftsmen » Craftsmen table saw 10'' model #11327610
Craftsmen table saw 10'' model #11327610 [message #29314] Wed, 01 December 2004 21:30 Go to next message
Jeff is currently offline  Jeff
Does anyone have any information on if parts and manual can be found for this saw. I found a rip fence on Ebay.
Re: Craftsmen table saw 10'' model #11327610 [message #29315 is a reply to message #29314] Thu, 02 December 2004 17:35 Go to previous messageGo to next message
Parts available at sears.com:
Model CRAFTSMAN BENCH SAW 10 IN. TILTING ARBOR - 11327610 (UNIT)
Part Description Part
Number Diagram
Reference
Number Quantity
GUARD INSERT 5509 1
CLAMPING KNOB 6319 2
LIFT PLATE ASSY. 6371 3
GUARD & SPLITTER BLADE ASY. (THIS PART MUST BE PURCHASED AS AN ASSEMBLY OR THE COMPLETE PART - RETURNED TO THE MANUFACTURER FOR REPAIRS.) 6382 4
BLADE BRACKET 72 5
CAP SCREW S-203 6
SPRING CLIP 6287 7
SCREW S-1272 8
CLAMP PIN 130 9
CLAMP ROD NUT 6407 10
PLAIN STEEL WASHER S-1214 11
RIP FENCE CLAMP 6410 12
FENCE PINION 3556 13
SCREW S-1241 14
TABLE INSERT 6151 15
TABLE 6387 16
SCREW S-1267 17
STEEL WASHER S-1261 18
SPRING WASHER 6423 19
ELASTIC STOP NUT S-1215 20
RETAINING RING S-1259 21
SUPPORT HINGE ROD 6426 22
BASE & BRACKET ASSEM. 6429 23
BASE SUPPORT ASSEM. 6428 24
CAP SCREW S-894 25
STEEL WASHER S-298 26
TABLE TRUNNION 13 27
LOCKWASHER 5/16 SAE MED. S-275 28
SCREW 60 29
HEX NUT S-1274 30
HANDWHEEL ASSEM. 146 31
HEADLESS SCREW SET S-323 32
SCREW W/EXTERNAL LOCKWASHER S-1275 33
FRONT PANLE STIFFENER 136 34
SCREW S-1276 35
BEARING BRACKET 54 36
LOCKWASHER 1/4 SAE MED. S-310 37
HEX NUT S-297 38
SCREW S-329 39
BEARING PLATE 55 40
FRONT PLANEL 5 41
TILT LIFT POINTER 35 42
TILT GAGE 61 43
SCREW S-602 44
SCREW S-626 45
STEEL WASHER S-299 46
TILT SCREW BLOCK 56 47
SPRING WASHER S-1212 48
CLAMP SCREW 17 49
SCREW HANDLE 18 50
SCREW SPRING 19 51
SCREW WASHER 6105 52
CAP SCREW S-860 53
SCREW W/EXTERNAL LOCKWASHER S-1278 54
MITRE GAGE POINTER 6388 55
CLAMP ASSEM. 6395 56
WING NUT 129 57
MITRE GAGE 6394 58
MITRE THUMB SCREW 126 59
GAGE WASHER 87 60
CLAMP KNOB 88 61
EXTEN. ROD - STRAIGHT 91 62
ROD CLAMP 93 63
CARRIAGE BOLT 128 64
MITRE EXTEN. ROD 92 65
GEAR RACK 6305 66
SCREW S-1265 67
SCREW S-1264 68
RIP FENCE GUIDE 6162 69
FENCE KNOB 141 70
CAM CLAMP LEVER 6408 71
LEVER INSERT 6113 72
CLAMP ROD 6409 73
CAM FACE 6111 74
SCREW S-1266 75
FENCE INDICATOR 135 76
ALIGNMENT BAR ASSEM. 6163 77
SCREW S-112 78
RIP FENCE 6415 79
CLAMP CUSHION 6112 80
ALLEN WRENCH FOR SCREW SET S-1242 81
BEARING RETAINER 3508 82
RETAINING WASHER 30 83
SPINDLE ARM PIN 15 84
SNAP RING 6383 85
ARBOR BEARING 3509 86
ARBOR HOUSING 6380 87
DEPTH DIAL RACK 32 88
TAPE SPRING 36 89
SPRING WASHER S-1211 90
TAPE PIN 23 91
STEEL WASHER S-970 92
STEEL WASHER S-1066 93
CLAMP WASHER 69 94
CLAMP SPRING 70 95
CAP SCREW S-1090 96
ARBOR KEY 3513 97
ARBOR NUT 6362 98
LOOSE COLLAR 27 99
CRADLE ASSEMBLY 3570 None
SAW ARBOR HSNG. ASSEM. 6392 None
MITRE GAGE ASSEMBLY 6403 None
RIP FENCE ASSEMBLY 6417 None
MOTOR SUPPORT ASSEMBLY 6427 None
DEPTH DIAL ASSEMBLY 67 None
OWNERS MANUAL 7858-5 None
SANDING DISC 5/8" BORE (PURCHASE FROM YOUR NEAREST SEARS RETAIL STORE OR MAIL ORDER HOUSE.) 9-2272 None
BOOKLET (THE CIRCULAR SAW) (PURCHASE FROM YOUR NEAREST SEARS RETAIL STORE OR MAIL ORDER HOUSE.) 9-2926 None
ARBOR WRENCH 3540 100
ARBOR ASSEMBLY 6393 101
CRADLE 14 102
RETAINING STUD 47 103
LIFT DIAL TAPE 34 104
DIAL GEAR 33 105
SAW BASE ASSEM. 6355 106
RETAINING RING 6331 107
LIFT SCREW COLLAR 6326 108
FLAT STEEL WASHER S-1156 109
STUD WASHER 6085 110
HEX NUT S-1204 111
JAM NUT S-1205 112
FIBRE WASHER S-1271 113
TILT NUT 58 114
NUT WASHER 3557 115
LIFT NUT 39 116
SCREW SPACER 6084 117
TILT SCREW 57 118
STEEL WASHER S-1283 119
SPRING WASHER S-1262 120
SCREW BLOCK 38 121
CAP SCREW S-1268 123
NUT BRACKET 6302 124
LIFT SCREW 6328 125
DADO INSERT (PURCHASE FROM YOUR NEAREST SEARS RETAIL STORE OR MAIL ORDER HOUSE.) 9-2212 126
SANDING INSERT (PURCHASE FROM YOUR NEAREST SEARS RETAIL STORE OR MAIL ORDER HOUSE.) 9-2283 127
V-PULLEY SINGLE GROOVE (PURCHASE FROM YOUR NEAREST SEARS RETAIL STORE OR MAIL ORDER HOUSE.) 9-2882 128
V-BELT 43 IN. X 1/2 IN (PURCHASE FROM YOUR NEAREST SEARS RETAIL STORE OR MAIL ORDER HOUSE.) 9-1643 129
COMB, TOOTH SAW BLADE (PURCHASE FROM YOUR NEAREST SEARS RETAIL STORE OR MAIL ORDER HOUSE.) 9-4937 130
SAW GUARD ASSEM. (PURCHASE FROM YOUR NEAREST SEARS RETAIL STORE OR MAIL ORDER HOUSE.) 9-2791 131
Re: Craftsmen table saw 10'' model #11327610 [message #29316 is a reply to message #29315] Thu, 02 December 2004 20:05 Go to previous message
Thanks for all the info!
Previous Topic: Vibration from enclosure surface
Next Topic: latest project
Current Time: Fri Mar 29 06:32:00 CDT 2024
