Vibration from enclosure surface [message #29298] |
Mon, 22 November 2004 15:00 |
GarMan
Messages: 960 Registered: May 2009
Illuminati (2nd Degree) |
Just wondering how vibration-free should the outer surface of an enclosure be. Over the weekend, I cranked some thump-aty-thump dance music passed 11 to my 2235's and was definately feeling vibrations on the outer surface of the enclosure. I pressed my ears against the side of the cabinet and was able to hear muted music from it. These cabinets are built from 3/4 MDF, double thickness front baffle, and braced top-to-bottom, side-to-side, and front-to-back. Do I need more padding or bracing? Gar.
Re: Vibration from enclosure surface [message #29305 is a reply to message #29303] |
Tue, 23 November 2004 11:43 |
Messages: 18677 Registered: January 2001
If a panel resonates at a particular frequency, it will be louder at that frequency. But even if it doesn't, it will still pass sound through it a little bit because sound passes through solids. If what you're hearing is muted uniformly except for more deep bass, then your cabinet is probably pretty solid. If it is louder at some midbass frequency, then you may have a panel that could use another brace.
