Home » Audio » Home Theater » JBL Subwoofer
JBL Subwoofer [message #28693] Wed, 18 March 2009 23:58 Go to next message
Kameena is currently offline  Kameena
Hey everyone,
I have a powered JBL subwoofer that's part of my home theater setup. Recently, however, it's been making machine gun noises when turned on.
I can let it blast a few times (10 to 15 times) until it stops, and then it works fine for like 20 minutes but automatically shuts off when it's had enough.
I've only done that twice, and am afraid to use it and ruin it now.
Does anyone know why it's doing that, or what I can do?
Re: JBL Subwoofer [message #28694 is a reply to message #28693] Thu, 19 March 2009 11:18 Go to previous messageGo to next message
Sounds like it's motorboating. If the power suply filter capacitors have become weak, this can happen. Basically what happens is the power supply fluxuates enough to cause a feedback loop. When power is first applied, the PS caps charge but the load rapidly depletes them enough to shut down the amp. The caps start to charge again, turning the amp back on but the load quickly discharge the caps and the cycle repeats. After awhile, the leaky electrolytic caps begin to work enough to hold a charge and keep the amp on, but just barely.
If that's what's happening, you can measure this with a scope across the power supply capacitors. Might be worth just replacing all the large electrolytic capacitors in the amplifier to see if that fixes the problem. I guess it depends how much the subwoofer is worth to you whether you should attempt the fix or simply replace the whole unit.
Re: JBL Subwoofer [message #28695 is a reply to message #28693] Thu, 19 March 2009 12:50 Go to previous messageGo to next message
So.... I don't know how I can fix it or how much it would cost to take to someone.
Is it bad to turn it on, let it 'motorboat' and then use it? How much longer 'till she dies?!
Re: JBL Subwoofer [message #28696 is a reply to message #28695] Fri, 20 March 2009 11:25 Go to previous message
There's no telling how long it will last. May last forever that way. It's sort of like turning it on and off again repeatedly - which isn't good, but may not kill it. Like I said, I'd swap the electrolytics and see if that didn't help. They don't cost much so it's an inexpensive fix.
Previous Topic: Wii video hack
Next Topic: Home Theater and BassMaxx - AWESOME!
Current Time: Sat Nov 07 09:55:22 CST 2026
