Home » Audio » Pro Sound » Re: Boundary effects
Re: Boundary effects [message #28400] Thu, 28 June 2007 16:39 Go to next message
Ka7niq is currently offline  Ka7niq
Thanks Wayne.
But will raising the port tuning compensate for this ?
The speakers are bass shy away from the wall on stands.
I have subwoofers, so low bass is not a consideration.
I just wish to warm em up a bit.
Will shortening port do this, and if so how much to shorten
Re: Boundary effects [message #28401 is a reply to message #28400] Sun, 01 July 2007 13:37 Go to previous message
Do not modify port length. Use the speakers in groups or with boundary loading. When using subs, you might choose a crossover point that makes boundary loading of the mains inconsequential.
Previous Topic: Amp mod question.
Next Topic: Prosound Shootout 2007
Current Time: Mon Nov 16 00:59:57 CST 2026
