Home » Audio » Pro Sound » Eminence driver that can handle 1250 wattts RMS, with heat sink
Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28110] Thu, 20 October 2005 07:31 Go to next message
I saw this at parts express:
Part Number 290-434
Sells for around $350 each. (Already has a heatsink in the front of the cone, I think).
It's an 18 incher with 97 db eff that can do 1250 watts rms.
Xmax: 9.8 mm.
Wonder what would happen with 2 of these and a suitably modified
12 pi cabinet. Should get 135 db SPL continuous you think?
-akhilesh
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28112 is a reply to message #28110] Thu, 20 October 2005 08:15 Go to previous messageGo to next message
That's the Eminence Kilomax, and you're right, it uses a small vented heatsink, probably why they were able to increase power handling 2x.
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28114 is a reply to message #28110] Thu, 20 October 2005 08:38 Go to previous messageGo to next message
Wouldn't work to good, for one thing the horn cabinet would be massive, another thing it dosen't have the magnetic strength (BL) for good cone control in a long horn, the fs is to high so it would have trouble getting down to 30hz. The Qts is also a little high for horn loading, you want Qts to be like between .2-.4 preferably. It would probably be kick ass in a horn that was designed for 50hz though, but not 30. Try running some models in McBeans and see what you come up with.
HTH
Bill W.
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28116 is a reply to message #28114] Thu, 20 October 2005 08:59 Go to previous messageGo to next message
Thanks Wayne & Bill.
I figured you guys knew about it, i was just browsing thru the catalog and saw it, and with the memory of the shootout fresh in my mind, thought about psting it here.
-akhilesh
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28117 is a reply to message #28116] Thu, 20 October 2005 09:24 Go to previous messageGo to next message
Design one up you can build it in my garage but they'll be bigger than your A-7's then you can see the look on your wife's face when you bring them in through the door LOL.
Bill W.
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28118 is a reply to message #28117] Thu, 20 October 2005 09:38 Go to previous messageGo to next message
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28120 is a reply to message #28117] Thu, 20 October 2005 10:52 Go to previous messageGo to next message
HEYYY!. My new ALtec system is up in my family room, and guess what?! My wife thinks it looks cool!
I think bringing in the A-7s was great to set the expectation bar really low in terms of WAF...she loves the "only 5 cubic inch" boxes I have now.
-akhilesh
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28121 is a reply to message #28120] Thu, 20 October 2005 12:31 Go to previous messageGo to next message
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28122 is a reply to message #28120] Thu, 20 October 2005 13:41 Go to previous messageGo to next message
5 cubic inch, don't tell us you went bose on us.:)
bill
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28123 is a reply to message #28122] Fri, 21 October 2005 09:41 Go to previous messageGo to previous message
I meant 5 cubic feet.
LOL
-akhilesh
Previous Topic: do karlson do anything well?
Next Topic: "Master" guitar amps
Current Time: Sat May 04 09:07:41 CDT 2024
