Home » Audio » Pro Sound » High output basshorn
Re: High output basshorn [message #27987 is a reply to message #27986] Sat, 06 November 2004 11:55 Go to previous messageGo to next message
Hi Tom,
You wrote:
>> Push pull mounting would cancel the second H (like using a push
>> pull transformer vs single ended) however of all the harmonics the
>> second is the least objectionable. That’s no reason not to do it
>> how ever.
Yes, that's what the shorting ring on a high-quality loudspeaker does too. That's why I asked Eminence to build the B12. The push-pull arrangement might actually work better at low frequencies though. We'll see.
As for the expansion of the room from the corner, I did some math and found it to be conical (of course) until the ceiling junction is reached, and then it becomes roughly parabolic. For visualization purposes, I compare the area expansion at different distances from the apex with a rectangular horn having straight walls in the post called "Room Corner Characteristics." I use this feature in some of my designs, but it isn't particularly germane to this particular horn. The horn I'm looking at right now is a high-power horn that probably won't be used in homes and its main feature is the push-pull plenum prior to the throat.
Wayne
Re: Boundary loading [message #27989 is a reply to message #27984] Sun, 07 November 2004 22:55 Go to previous messageGo to next message
hulkss is currently offline  hulkss
Just a couple quick commments:
The original LABsub has a compression ratio of 2:1. I have a modified pair at 3.0 compression ratio.
1 dB is .0000000029 psi
15 psi would be: 20log(15/.0000000029)= 194 dB
The actual peak horn throat SPL is more like 155 dB which is 0.2 psi.
High Hz? [message #28013 is a reply to message #27985] Sun, 02 January 2005 04:50 Go to previous messageGo to next message
rick57 is currently offline  rick57
Hi Wayne
What do you have in mind as the top end of the effective FR?
Cheers
Re: High Hz? [message #28016 is a reply to message #28013] Sun, 02 January 2005 14:46 Go to previous message
Upper response to 150Hz or so.
Previous Topic: solid state guitar amp ....... wanna make a kzillion$ ?
Next Topic: Bass cabinet design
Current Time: Mon May 06 04:43:59 CDT 2024
