Home » Audio » Pro Sound » Phantom power / ribbon mics
Phantom power / ribbon mics [message #27736] Thu, 11 August 2005 10:18 Go to next message
phutloose is currently offline  phutloose
I often use Octava ML52 ribbon mics and have scary moments when plugging them in in case phantom power is being sent down the lead.
Ocasionally I come across desks that only alow phantom switching in grops of channels so I cant specifically switch of phantom on a particular channel.
I often loan them to friends so I cant be positive people wont check phantom before pluging in.
Is there a device or way of wiring a mic lead so that it strips the phantom without affecting the signal?
Any help appreciated
Thanks
Ph
Re: Phantom power / ribbon mics [message #27738 is a reply to message #27736] Thu, 11 August 2005 12:04 Go to previous message
One way is to install a cap of about 47uF in line with the signal cable.
Bill W.
Previous Topic: Dimebag's chainsaw sound
Next Topic: Tsl 601 No Sound!
Current Time: Sat Oct 17 23:08:32 CDT 2026
