Home » Audio » Pro Sound » Where / how do I replace a blown JBL EON G2 horn?
Where / how do I replace a blown JBL EON G2 horn? [message #27730] Wed, 15 June 2005 04:42 Go to next message
CHIP ROBERTS is currently offline  CHIP ROBERTS
I don't know how this happened! This speaker was being used in a 6 EON monitor set-up. It was positioned , side by side , in the middle of the stage for vocals.
Oh well , I guess these things happen. But I don't know where to get what I need , what it even is , or how much it would be to get it replaced. So if anyone has any suggestions , that would be smooth.
Thank you ...
Re: Where / how do I replace a blown JBL EON G2 horn? [message #27731 is a reply to message #27730] Wed, 15 June 2005 06:50 Go to previous message
Here's the user's manual, hopefully it will help you find the trouble. If it's really damaged, maybe you can send it in for warranty repair.
Previous Topic: building a 150watt tube guitar-amp-head
Next Topic: A good, non-technical article on impedence matching
Current Time: Sun May 26 03:31:08 CDT 2024
