Home » Audio » Pro Sound » concert series JBLs 8 pin connection
concert series JBLs 8 pin connection [message #27709] Fri, 11 February 2005 14:56 Go to next message
Jeremy is currently offline  Jeremy
I got some jbl 4871's as hand-me-downs and I am not sure how to hook them up correctly. they have the 8pin connect and from what I understand, I need a tri-amp system to run them. How do I hook them up? the guy that gave them to me made some adapter to basically take the 8pins down to a standard banana clip... but wont I blow them if I hook it up to just one amp like that?
Re: concert series JBLs 8 pin connection [message #27710 is a reply to message #27709] Fri, 11 February 2005 20:59 Go to previous message
You might try to search the technical documents at www.jblpro.com. They may have a schematic that shows the pinouts online there.
Previous Topic: EVM 12L box
Next Topic: I want to build a Small Class A tube amp .
Current Time: Mon May 06 04:27:10 CDT 2024
