Home » Audio » Pro Sound » Peavey Heritage VTX Normal Gain Noise Problem
Peavey Heritage VTX Normal Gain Noise Problem [message #27536] Sat, 29 December 2007 07:15 Go to next message
Tomo is currently offline  Tomo
Hi,
I've bought second hand Peavey Heritage VTX a few months ago.
It suddenly start huge Low distorted noise when I turn a post gain nob on Normal Gain,
although if I turn the post gain on Normal Gain off and turn up the post gain on Lead Gain it works fine.
I have put in brand new valves but it's still the same.
I am new to this amp and downloaded manual but it isn't helpful.
Can anyone could help me to find out how to get rid of this problem?
Thanks
Tomo
Re: Peavey Heritage VTX Normal Gain Noise Problem [message #27537 is a reply to message #27536] Sat, 29 December 2007 16:47 Go to previous messageGo to next message
decoy is currently offline  decoy
I'm not to familiar with this amp either, but my fender princeton had a similar problem and I just cleaned out the pots and changed a couple of relays and it works fine. Give it a try. I would suggest getting a good tech.
Re: Peavey Heritage VTX Normal Gain Noise Problem [message #27538 is a reply to message #27537] Sat, 29 December 2007 17:50 Go to previous message
Hi,
Thank you for your reply.
Strangely enough, I have left it on with all nobs off for over an hour, then it stopped making noise...
Anyway thank you very much for your advice!
Tomo
Previous Topic: Merry Christmas to everyone! nt
Next Topic: Small basshorn specs
Current Time: Mon Apr 29 11:17:27 CDT 2024
