Home » Audio » Pro Sound » faulty reverb
faulty reverb [message #27488] Mon, 08 October 2007 19:21 Go to next message
ratchet1021 is currently offline  ratchet1021
having trouble with the reverb on a silver face fender deluxe. have replaced the reverb unit itself, fully retubed the amp. when turning the verb up it seems to boost the sound but doesnt have any reverb to it, and when you get up to 7 it starts squeeling very loud. ive takin the tank out and put it in my twin and it seems to work. will listen to any suggestions, ideas, help advice. gotta get this thing working
Re: faulty reverb [message #27520 is a reply to message #27488] Fri, 09 November 2007 13:00 Go to previous message
decoy is currently offline  decoy
I have the same problem with my princeton, Try changing the wires that go out of the tank they should just be AV wires. If that doesn't work try changing the in wires.
Previous Topic: which amp
Next Topic: Speakerplans
Current Time: Thu Nov 19 21:32:05 CST 2026
