Home » Audio » Pro Sound » Peavey Artist VT Series
Peavey Artist VT Series [message #27477] Sun, 23 September 2007 23:37 Go to next message
Greene is currently offline  Greene
These amps take 4 x 6L6GC tubes in the output section. Are these required to be a matched set of tubes? Can I fit a non matched set of tubes? DogNut
Re: Peavey Artist VT Series [message #27479 is a reply to message #27477] Mon, 24 September 2007 09:13 Go to previous messageGo to next message
It will work with tubes that aren't matched, but it would be better to get a matched set. It will help reduce noise and may improve sound quality, particularly at high drive levels.
Re: Peavey Artist VT Series [message #27480 is a reply to message #27479] Tue, 25 September 2007 02:23 Go to previous message
Thanks Wayne. I have a couple of TAD short bottle tubes with a rating of 60 on the plate? If I match them with 2 more TAD short bottles something close to the same rating would that go ok? I suppose the question is: is those short bottle 6L6GC tubes a raesonable choice for that type of amp? Thanks DN.
Previous Topic: Fender Vibrolux Silverface '73
Next Topic: Marshall JCM900 SL-X 100watt
Current Time: Sun Nov 08 17:03:56 CST 2026
