Home » Audio » Pro Sound » VOX ac30 The cloth
VOX ac30 The cloth [message #27430] Sat, 12 May 2007 07:59 Go to next message
Per Sundin is currently offline  Per Sundin
Hi I am a owner of a new custom classic Vox ac30. but i have a porblem, and I have seen it on a lot of ac30, the front cloth stars to lose it's gripp. I know this must bee a problem for more peoples then me so if some one have a tips please tell me! What should i do?
Re: VOX ac30 The cloth [message #27565 is a reply to message #27430] Tue, 11 March 2008 03:00 Go to previous message
colton is currently offline  colton
Mine did the same. What you need to do is get super glue and needle nose pliers. Pull the gold band off. First you stretch the cloth upward with the pliers, hold it there by pushing your finger against it, with your other hand put super glue in the slot. Then with the needle nose pliers, use the tip to push the cloth down over the glue and hold. Repeat. hope it helped
Previous Topic: Orange Amps? or Marshall Amps?
Next Topic: Amps not getting any signal...Help please!
Current Time: Thu Nov 19 07:19:07 CST 2026
