Home » Audio » Pro Sound » Ground Lift Plugs?
Ground Lift Plugs? [message #27419] Sun, 29 April 2007 09:15 Go to next message
Ricardo is currently offline  Ricardo
I've worked with guys who used ground lift plugs to get rid of a 60 cycle hum, but didn't properly attach the ground wire.
I assume they're safe if you do that. Has anybody ever had a bad experience using them?
Re: Ground Lift Plugs? [message #27421 is a reply to message #27419] Sun, 29 April 2007 21:00 Go to previous message
A ground lift plug can stop hum IF it's being cause by a ground loop between two pieces of gear. Otherwise, it'll do nothing to stop hum and may even make it worse. Plus, it should be considered a "band aid fix" only. Ungrounded guitar amps are always a shock hazard, no matter how small said hazard may be.
It's especially bad in old buildings where you have to use the ground lift plug to use the old two prong outlet, or in buildings that may not be wired to code. If another piece of equipment is plugged into its outlet in the opposite phase, touching the equipment or person in contact with it will give you both a very unpleasant surprise.
Thermionic
Previous Topic: Peavey Amp Problem
Next Topic: picking up radio ststion through amp
Current Time: Thu Nov 26 19:00:28 CST 2026
