Home » Audio » Pro Sound » MG50DFX as a head unit??
MG50DFX as a head unit?? [message #27169] Sat, 10 December 2005 03:34 Go to next message
LauzzaFenderBoy™ is currently offline  LauzzaFenderBoy™
heya im buying a cab for xmas, probably marshall AVTC412A (the angled one) just as my first budget half stack and then i hope to get the B cab, and then a proper head unit, i hav a marshall MG50DFX amp, can i use that as a head unit, and if so, which wires will i need to connect the cab to the 50DFx, as im told its a bad idea to use guitar leads, any help and direction would be considered very useful.
thanks FenderBoy™
Re: MG50DFX as a head unit?? [message #27582 is a reply to message #27169] Wed, 28 May 2008 17:38 Go to previous message
alespualdude is currently offline  alespualdude
i got a mg50 two just make sure the ohms are the same and th cab can handle 100w
Previous Topic: New Free Downlodable IRs & Presets
Next Topic: Fender blues junior vs. Peavey Valveking 212/112
Current Time: Fri Oct 23 06:12:28 CDT 2026
