Home » Audio » Pro Sound » Mashall AVT footswitch repair
Mashall AVT footswitch repair [message #27149] Thu, 06 October 2005 20:50 Go to next message
arsbadmojo is currently offline  arsbadmojo
Hello all, this post is just to make it easier if you need to repair your AVT footswitch. Mine went bad and the amp would get stuck on OD2.
If you are handy with a soldering iron, the part is easilly replaceable. I found an exact match from Mouser electronics - they are made by Alpha Switch Co. of Taiwan. Mouser part number 107-SF12011-M. This is just for the channel selector switches. The FX switches are the same part number, but end in L instead of M. They run about $6 each - a lot cheaper than a new switch.
Hope it helps someone out there!
Re: Marshall AVT footswitch repair [message #27150 is a reply to message #27149] Fri, 07 October 2005 02:25 Go to previous message
Good info, thanks!
Previous Topic: Guitar Amp Quesiton
Next Topic: Infrequent amp useage
Current Time: Sun Nov 29 03:19:17 CST 2026
