Home » Audio » Pro Sound » AVT150
AVT150 [message #27078] Sun, 26 June 2005 18:35 Go to next message
corey is currently offline  corey
Hi, i recently plugged my AVT 150S SPEAKER OUTPUTS INTO MY COMPUTER NAD IT stopped working. I later looked up and read that it was probobly due ot the fact i should only plug the output into 4 ohms, but it wont turn on at al and i beileve a fese is blown, could anyone help me on a home solution to this problem?
Re: AVT150 [message #27080 is a reply to message #27078] Sun, 26 June 2005 22:50 Go to previous messageGo to next message
Could also be that the amplifier outputs should be isolated and not connected to earth ground. What fuse is blowing?
Re: AVT150 [message #27081 is a reply to message #27080] Mon, 27 June 2005 10:46 Go to previous messageGo to next message
I cant even find the fuses on it at all but it wasnt on the ground it was still sitting on the cabinet
Re: AVT150 [message #27082 is a reply to message #27081] Mon, 27 June 2005 11:25 Go to previous message
I'm talking about electrical connections, and that the amp may not work with a speaker wire being grounded. The (+/-) speaker outputs may be a complementary pair instead of single ended.
Previous Topic: speaker cabinet troubles
Next Topic: Marshall TSL 100 problem
Current Time: Mon Oct 19 13:25:16 CDT 2026
