Home » Audio » General » 12inch full range driver in tl enclosure
12inch full range driver in tl enclosure [message #26764] Wed, 15 April 2009 07:22 Go to next message
jonviolet is currently offline  jonviolet
Hi all ,i was listening to some imf tls 80s that i found at a recycle depot. and fully enjoyed the deep bass and soundstage. These are not my usual listen i like full rangers like goodmans and tannoys . i was wondering as the front baffle is removable on the imfs could i fit a 12inch full ranger instead of the inefficient array of drivers that are in it? what would the effect on sound be would it be any good ??? look forward to your replys good or bad
Re: 12inch full range driver in tl enclosure [message #26765 is a reply to message #26764] Thu, 16 April 2009 12:37 Go to previous message
I think if you do some analysis to find the right driver matched to the cabinet, your chances of success would be much greater.
Previous Topic: ART mentioned in GUITAR WORLD
Next Topic: Lone Star Audio Fest Update
Current Time: Thu Nov 05 02:23:07 CST 2026
