Home » Audio » General » Prroblem with Marantz 2270 "Dialcord"
Prroblem with Marantz 2270 "Dialcord" [message #26723] Tue, 14 October 2008 02:40 Go to next message
slbender is currently offline  slbender
Hi guys,
I'm having a problem restringing the dial cord after replacing some fuse lamps on this set. Turns out my Marantz 2270 isn't quite the same as is pictured in the Service Manuals' pictorial diagram.
The S.M. is for a Marantz 2270 that has different parts. My set allows operation on either 117 or 220 Volt AC lines and has a Phono 1 and Phono 2 input while the S.M. unit only has a 117 Volt transformer and only one Phono input.
So does anyone have an alternate dial cord string diagram ???
tnx,
Steven
Re: Prroblem with Marantz 2270 "Dialcord" [message #26724 is a reply to message #26723] Tue, 14 October 2008 16:17 Go to previous message
I've run into a variety of dial cord layouts because I collect old tube radios. For me, it has been most effective to visualize the path and use thick thread to string it, connecting each end in the middle of the travel with a small spring to hold tension.
Previous Topic: harmon kardon cd 191 and Akai AA-A45
Next Topic: Philco Hi-Fi Record Player
Current Time: Thu Nov 05 06:59:21 CST 2026
