Home » Audio » General » Pics of Amps
Pics of Amps [message #26567] Fri, 11 August 2006 19:16 Go to next message
Leland Crooks is currently offline  Leland Crooks
Here's some pics of the Pilotone and the Bogen. Any suggestions, tips or observations are very welcome.
Potentiometer on board?
Tape head? Tape Amp?
Bogen
XTAL?
Excellent! [message #26568 is a reply to message #26567] Fri, 11 August 2006 22:53 Go to previous messageGo to next message
You have some cool stuff there! I don't have any real good comments or suggestions, just some loose thoughts. I'd probably trace the circuit to try and figure out the unknowns. The tape ins and outs I'm guessing accept different levels, but that's just a guess. The pot may be a hum bucking pot. Xtal may be an auxilliary input; I doubt it's a crystal connection for a tuner circuit, but I don't know. Maybe others will chime in with better info.
Re: Pics of Amps [message #26570 is a reply to message #26567] Sun, 13 August 2006 08:56 Go to previous messageGo to next message
MWG is currently offline  MWG
Those are some nice looking amps you have. The Bogen looks to have some good sized transformers on it.
Re: Pics of Amps [message #26571 is a reply to message #26570] Mon, 14 August 2006 16:47 Go to previous messageGo to next message
Leland is currently offline  Leland
My friend in the TV/Audio business loaned me a variac. He had to scrounge to find one. I've fired up the bogen with a 12 hr breakin. Going to listen tonite. Pilotone is next.
I have a bunch of mono blues and jazz recordings in 78 and 33 from the 50's I picked up at an auction. I'm thinking the pilotone is just the ticket. Now I need to find a tt with 78. My old technics is 33 and 45.
Re: Pics of Amps [message #26572 is a reply to message #26571] Mon, 14 August 2006 19:16 Go to previous message
I would look for a Dual 1009 or 1019. I believe both have 78 and the tall spindle to hold 6 records. They will treat your records better than any other changer I know of. Good listening
Previous Topic: Mannerly Behaviour
Next Topic: Out-of-print Audio mags
Current Time: Mon Oct 26 07:24:18 CDT 2026
