Home » Audio » General » MG 1's
MG 1's [message #26291] Sun, 01 May 2005 22:05 Go to next message
MWG is currently offline  MWG
I found a pair of these cheap today and really like the way they sound. One speaker needs either e new grill cloth or I need to figure out how to patch two holes about the size of quarters. These are perfect for listening to when you don't want a lot of volume. My Altecs don't seem to come alive until around 95+db on the meter or maybe my hearing is just going south
Re: MG 1's [message #26292 is a reply to message #26291] Mon, 09 May 2005 13:46 Go to previous messageGo to next message
What are you driving the Altecs with?
Re: MG 1's [message #26293 is a reply to message #26292] Mon, 09 May 2005 22:36 Go to previous messageGo to next message
I use a MC-2505 I bought in 1971. I'm going to try borrowing an amp that has 100WPC or more and see if that helps. Maybe I have planars confused with electrostatics. I was expecting really pronounced highs but these sound like my Wharfdales. A fellow from Magnepan called today but I was at work. Hopefully I'll be able to talk to him on Friday.
Re: MG 1's [message #26294 is a reply to message #26293] Mon, 09 May 2005 22:39 Go to previous messageGo to next message
I forgot to mention I have a MC-275 that I plan on using as soon as I can get it fixed. The Altecs loved the tube amp while it worked.
Re: MG 1's [message #26295 is a reply to message #26294] Tue, 10 May 2005 10:13 Go to previous messageGo to next message
With Altecs I think it is more about the power supply of the amp; that would explain why the 275 sounds good.
Re: MG 1's [message #26370 is a reply to message #26293] Tue, 16 August 2005 12:11 Go to previous message
zobsky is currently offline  zobsky
Mg 1 don't have extended high freq. , . IIRC, they are only spec'd out till 16KHz or so
Previous Topic: OT: Are there web hosts with templates so I don't have to learn another freaking software package?nt
Next Topic: Wrongsideofthetracksaudiofest
Current Time: Fri Nov 27 07:29:02 CST 2026
