Home » Audio » General » tubes
tubes [message #26242] Wed, 29 December 2004 09:13 Go to next message
Wayne the tube tester is a good idea and good starting place ---but I would like to have a good set of the same brand of tubes in an amp ( I have a Pilot and Knights and fishers that all use the same type of tubes) and can move them from one amp to another to hear differences in them----one test I read from some ebay aauction is to test the tubes at amp voltages as opposed to testing at 150 volts ---your thoughts Jim
Re: tubes [message #26243 is a reply to message #26242] Wed, 29 December 2004 11:38 Go to previous message
Absolutely. But tube testers have a voltage adjustment, so it isn't fixed at a specific value. The voltage a tube is run at sets its operating point. Look at load lines and you'll see the differences. In the linear region, increasing voltage increases current by a proportional amount. Load lines plot the transfer curves.
Previous Topic: New Roland Cube 60
Next Topic: new years
Current Time: Thu Nov 05 02:53:24 CST 2026
