Home » Audio » Radio » RCA Victor Radio Model 1-R-81
RCA Victor Radio Model 1-R-81 [message #25981] Sat, 17 November 2007 16:10 Go to next message
sandy is currently offline  sandy
Hi, just purchased the above radio today in mint condition and all works. AM FM. Golden Throat Label on Back, Model and Serial number labels on the bottom, can give you serial number if it helps. Wondered the price range it was worth. Saw one kind of like it for $20 and another for $200. approx 2 ft wide and 1 ft deep, has all knos and we are listening to it now. Any help would be appreciated.
Thanks, Sandy
Re: RCA Victor Radio Model 1-R-81 [message #25984 is a reply to message #25981] Sun, 18 November 2007 17:47 Go to previous message
Radios like these are usually worth more intrinsically than extrinsically. Your earlier search gives you a real good indication of the price range. You can probably find a schematic for it in the Rider collection if you need it. Chances are, if it hasn't been used in a while the capacitors are probably bad. The tubes may still work though. Power it on and give it a try. Check the power cord and make sure it isn't frayed though first.
Previous Topic: RCA Victor Console Radio
Next Topic: Wards Airline Phono/amfm floor Model
Current Time: Mon Nov 23 00:12:31 CST 2026
