Home » Audio » Radio » Need Radiola Model 17 Tuning Wheel
Need Radiola Model 17 Tuning Wheel [message #25697] Tue, 24 May 2005 22:12 Go to next message
Charlie S. is currently offline  Charlie S.
I have acquired a Radiola model 17 with a broken tuning wheel. This is the pot metal wheel that goes on the shaft of the tuning condenser.
Since I have all the pieces of the old tuning wheel I'm wondering if I can just epoxy it back together and make this radio sing. Has anybody had any luck doing this? I think I would still want to get a replacement wheel in the long run if possible.
Re: Need Radiola Model 17 Tuning Wheel [message #25698 is a reply to message #25697] Wed, 25 May 2005 06:19 Go to previous message
Yeah, you could probably do that but I'd definitely find an old scrap radio to swap with. If you're lucky, you'll find one that has the pully attached with a set screw instead of being pressed on.
Previous Topic: atwater kent radio
Next Topic: Please Help Me Identify Freshman Model Number
Current Time: Wed Nov 04 23:15:28 CST 2026
