Home » Audio » Radio » zenith H724Z
zenith H724Z [message #25651] Tue, 15 February 2005 11:54 Go to next message
styles is currently offline  styles
hi, have to change caps can't find .005 , .004 , .02 ,.05 what values can i use to replace them...thanks ..rob
Re: zenith H724Z [message #25653 is a reply to message #25651] Tue, 15 February 2005 22:18 Go to previous message
Those are pretty common values, but sometimes it's easier to find some in-between values like 22, 2.2 or 0.22 than a round value like 2.0. Other common values are 3.3, 4.7, 5.6 and 6.8. Usually you can go to the nearest value, rounding up if the desired value is right in-between. That works just fine for coupling and bypass capacitors.
Previous Topic: wards airline radio
Next Topic: Need years for radios
Current Time: Tue Oct 27 19:25:58 CDT 2026
