Home » Audio » Measurement » What are the differences of the sound when using different isolation transformers?
What are the differences of the sound when using different isolation transformers? [message #25283] Mon, 16 March 2009 00:36 Go to next message
auchain is currently offline  auchain
Could you hear the differences of the sound when using an isolation transformer (toroidal, R or EI core transformer, for example) in your audio gear?
And could you describe what the differences are?
Re: What are the differences of the sound when using different isolation transformers? [message #25284 is a reply to message #25283] Mon, 16 March 2009 13:04 Go to previous message
In some cases, the reduction of hum is substantial. It really depends upon the condition, quality and configuration of the earth ground connections. An isolation transformer can break a ground loop, which in turn can result in the reduction of noise.
Previous Topic: Calibration microphone help needed
Next Topic: On axis measurements in nearfield listening
Current Time: Fri Oct 16 17:11:04 CDT 2026
