Home » Audio » Measurement » Anechoic or In-Room?
Anechoic or In-Room? [message #25178] Wed, 15 September 2004 12:25 Go to next message
Oberon is currently offline  Oberon
Which measurement you think is more important to know?
Re: Anechoic or In-Room? [message #25179 is a reply to message #25178] Thu, 16 September 2004 12:12 Go to previous message
Ranier is currently offline  Ranier
It depends on what you want to know. If you want to know how your room setup is, to tailor it and know what treatments are needed, in room is obviously the way to go. If you want a baseline of a product for comparison, then anechoic or outdoors is best. Otherwise there is no common ground, because you are comparing apples and oranges with room conditions influencing the measurements.
Ranier
Previous Topic: RTA
Next Topic: SAT
Current Time: Tue Nov 03 11:37:39 CST 2026
