Home » Audio » Room Acoustics » Non-fugly room treatments
Non-fugly room treatments [message #24998] Fri, 05 March 2004 09:51 Go to next message
Nebs is currently offline  Nebs
Are there any non-ugly wall treatments? I'm looking for something to do my opposing walls, something like the foam wedges but I don't want them to be so ugly. Suggestions?
Re: Non-fugly room treatments [message #24999 is a reply to message #24998] Tue, 09 March 2004 00:32 Go to previous messageGo to next message
Yes there are room treatments which are not ugly.
How you define "ugly" comes into play. Being massive in itself may be intruding or ugly.
You can get neat ones out there.
Re: Non-fugly room treatments [message #25004 is a reply to message #24998] Wed, 10 March 2004 13:49 Go to previous message
Audio Jones is currently offline  Audio Jones
You might consider installing an acoustical soffit instead. Check with a consulting firm if you're really serious.
Previous Topic: Bass traps
Next Topic: Room gain AKA cabin gain
Current Time: Tue Nov 03 13:18:49 CST 2026
