Home » Audio » General » How Much Memory Is Sufficient?
How Much Memory Is Sufficient? [message #24925] Tue, 22 May 2007 08:55 Go to next message
Ricardo is currently offline  Ricardo
I only have a couple small MP3 players with 512 meg of memory, plus one of them takes an SD card. I think the most memory they have is 2 gigs.
How much memory do you think is sufficient for your personal MP3 player? Some of these iPod sizes seem a little like overkill to me.
Re: How Much Memory Is Sufficient? [message #24927 is a reply to message #24925] Sun, 27 May 2007 13:47 Go to previous messageGo to next message
The more memory you have, the more songs you can store. Higher quality files are larger too.
Re: How Much Memory Is Sufficient? [message #24929 is a reply to message #24925] Sun, 03 June 2007 10:37 Go to previous messageGo to next message
Depends what you want to do. Lots of people put their whole catalog on them at a very high quality, so 60 gig is nice. I can get by with 2 gig myself. I can put 100 or so songs on at CD quality bitrate which works great. I am constantly swapping out songs on it so the lower memeory works fine. I usually only listen to 5-10 different artists at any one time and then when I'm tired of them move on to somebody else.
Re: How Much Memory Is Sufficient? [message #24930 is a reply to message #24927] Mon, 18 June 2007 07:46 Go to previous messageGo to next message
Sorry, I meant how much memory do you actually use?
My music collection exists on CD and DVD, but if I hadn't bought the disks, I guess it's conceivable I'd want to store it all on an iPod or other device.
Two or three gigs is probably plenty for me.
Re: How Much Memory Is Sufficient? [message #24951 is a reply to message #24930] Thu, 04 October 2007 13:37 Go to previous messageGo to next message
Gilipsie is currently offline  Gilipsie
I have over 10,000 songs stored. It depends on what you are working with as far as music is concerned.
Re: How Much Memory Is Sufficient? [message #24972 is a reply to message #24925] Mon, 22 October 2007 23:33 Go to previous message
Crystal is currently offline  Crystal
I love music and all types of music. I think that I would need atleast 1 Gb of space. I would use the 512 MB though, I would just replace the music every few days or so.
Crystal
Previous Topic: sansui 9090db
Next Topic: Handheld TV
Current Time: Wed Oct 21 19:12:31 CDT 2026
