Home » Audio » Speaker » Licron??
Licron?? [message #24704] Thu, 02 June 2005 19:11 Go to next message
Jerry Kinzel is currently offline  Jerry Kinzel
Does anyone have experience with an anti-static agent called Licron
(http://www.techspray.com/newinfo/1755.pdf). I'm looking for a diaphram coating that could be applied after attachement to the stators and thought a spray such as this might work?? If anyone has any thoughts on the suitability of a product such as this, they would be greatly appreciated! Jerry
Re: Licron?? [message #24705 is a reply to message #24704] Thu, 02 June 2005 23:01 Go to previous messageGo to next message
moray james is currently offline  moray james
Hey Jerry: check out the thread on Licron over at DIYaudiodotcom. Regards Moray James.
Re: Licron?? [message #24707 is a reply to message #24705] Fri, 03 June 2005 09:18 Go to previous message
Moray, thanks, next time I will do a better search! Based upon the infomration presented, I think I will give it try! Thanks again, Jerry
Previous Topic: High Voltage Supply Filtering
Next Topic: just to shake things up
Current Time: Tue Nov 03 07:07:35 CST 2026
