Home » Audio » Speaker » C-T-C spacing ?
C-T-C spacing ? [message #24233] Wed, 26 March 2008 00:05 Go to next message
Dan is currently offline  Dan
If I have 11" C-T-C spacing on all my drivers will I have comb filter issues with a point source tweeter crossed over at 1K
I know 11" = 1234Hz, and that 1K would be with in the 11". But how do the outer drivers affect the situation?
Thanks
Dan
Re: C-T-C spacing ? [message #24234 is a reply to message #24233] Wed, 26 March 2008 01:11 Go to previous messageGo to next message
Marlboro
no comb in the scenario you describe: 13560in/sec /11inches c-to-c=1232hz, crossover needs to be below that, but its tight. You need a steep crossover.
Outer speakers not related.
Re: C-T-C spacing ? [message #24238 is a reply to message #24233] Thu, 27 March 2008 16:44 Go to previous messageGo to next message
Rick Craig is currently offline  Rick Craig
The comb filtering will start at a lower frequency than 1K.Unless you have a tweeter that can cross really low I would consider smaller diameter woofers.
Thanks Rick *NM* [message #24244 is a reply to message #24238] Fri, 28 March 2008 11:30 Go to previous message
NM
Previous Topic: Affect of speaker in front of speaker
Next Topic: Will this work
Current Time: Sun Nov 08 12:35:30 CST 2026
