Home » Audio » Speaker » Is Roger Russell Right ?
Is Roger Russell Right ? [message #24201] Thu, 06 March 2008 15:35 Go to next message
chris is currently offline  chris
he is using arrays of single wide range drivers, and he uses a bit of EQ at the frequency extremes.
His newest designs use small fiberglass cone speakers that are inherently wide range, and then he adds some EQ.
Here Is The Link To The Roger Russsell Array Page [message #24203 is a reply to message #24201] Thu, 06 March 2008 15:53 Go to previous messageGo to next message
I found this interesting reading.
Here is the link
What do YOU think ?
Re: Here Is The Link To The Roger Russsell Array Page [message #24205 is a reply to message #24203] Fri, 07 March 2008 09:51 Go to previous messageGo to next message
I heard Roger's full-range-driver line arrays at the 2006 RMAF, and I liked the sound I was hearing. Also, a pair of 7' 6" line arrays is a wonderful thing to behold. The shortcoming was a lack of "air" at the treble extremes. Problem is, even if I won the lottery I couldn't justify spending $19,000 for speakers with that shortcoming, when for about one third that amount or less I could have a pair of Selah Audio or AV-123 line arrays that do everything very well.
a lack of "air" at the treble extremes [message #24206 is a reply to message #24205] Fri, 07 March 2008 17:55 Go to previous message
Marlboro
Indicative of comb filter distortion starting at 12Khz, and which cannot be "fixed" with equalization.
Previous Topic: More Low Cost Drivers
Next Topic: What music do you listen to NOW.....?
Current Time: Thu Nov 19 09:24:02 CST 2026
