Home » Audio » Speaker » Art arrays are done
Art arrays are done [message #23425] Sat, 03 February 2007 21:32 Go to next message
Frean is currently offline  Frean
Well I have the hooked up and they sound great... Fred you rock!!!
Excellent! [message #23426 is a reply to message #23425] Mon, 05 February 2007 15:45 Go to previous messageGo to next message
I thought Fred did a great job designing these speakers too. Yours look excellent! What kind of wood is that? What finish?
Very Nice [message #23432 is a reply to message #23425] Wed, 07 February 2007 09:09 Go to previous messageGo to next message
Eric is currently offline  Eric
Nicely done! Will you elaborate on the sound?
Re: Art arrays are done [message #23434 is a reply to message #23425] Wed, 07 February 2007 13:34 Go to previous messageGo to next message
They look great! As far as I know yours are the first. Give them a week or two to break in, experiment with placement until you find the best position in the room, then give us your impressions.
Re: Excellent! [message #23436 is a reply to message #23426] Fri, 09 February 2007 04:43 Go to previous messageGo to next message
FJC is currently offline  FJC
Thanks Wayne, the finish is a faux finish that looks like wood... It works really well and cheap...
Re: Excellent! [message #23437 is a reply to message #23436] Fri, 09 February 2007 13:05 Go to previous messageGo to next message
What is the finishing product? I might want to use in on some future project. Always looking for the impossible: cheap audio equipment that sounds like the high end stuff, easy to apply finishes that look expensive, etc.
Re: Art arrays are done [message #23440 is a reply to message #23434] Tue, 13 February 2007 16:09 Go to previous messageGo to next message
ttan98 is currently offline  ttan98
Fred,
I email PE, the manager did not response after at least 2 emails requesting transportation costs for the drivers. Maybe I should give up.
Alternatively, can I use GR driver M130 instead, it may cost a little bit more, and Danny from GR is very user friendly. What is your opinion? I believe the sound will improve as they are better drivers compared to Dayton.
Re: Art arrays are done [message #23441 is a reply to message #23440] Tue, 13 February 2007 18:33 Go to previous messageGo to next message
Scott told me to have buyers call him so he can get the information he needs to set up a special one-time wholesale account for you. I suggest you call him.
Re: Art arrays are done [message #23442 is a reply to message #23441] Tue, 13 February 2007 18:39 Go to previous messageGo to next message
thanks..
Re: Art arrays are done [message #23443 is a reply to message #23441] Tue, 13 February 2007 18:49 Go to previous messageGo to previous message
By the way is GR M-130 better than the PE Dayton driver, hence sounds better. If that is so then it is better to get M-130 now to avoid upgrade in future. The price difference is marginal and I also strongly suspect postal charge from GR is cheaper than PE, therefore M-130 will not much more expensive than PE's Dayton.
your opinion please.
Previous Topic: Thinking About Buying Infinity RS 1 B'S ?? Scared !
Next Topic: Newform R30 / Scan 8545 array
Current Time: Thu May 02 14:38:55 CDT 2024
