Home » Audio » Speaker » array impedance
array impedance [message #22987] Thu, 20 April 2006 17:46 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy . some one could aswer this question . I have twelve 6.5 inchers woofers to build a line array .... wich final impedance will work better a 8 ohm or a 4.5 ohm configuration.? thanks
Re: array impedance [message #22988 is a reply to message #22987] Thu, 20 April 2006 21:17 Go to previous message
With just this much information I doubt that anyone could accurately answer your question. A number of things come to mind such as:
1. How much sensitivity do you require from your woofer array?
2. Have you taken baffle step compensation into account?
3. Do you plan to power taper your woofer line?
3. Can your amplifier drive the 4 ohms load without shutdown?
and so on.
Perhaps you could provide us with some more details and we could address your impedance question.
Jim
Previous Topic: Re: Array driver question
Next Topic: Two way- conventional and coaxial
Current Time: Mon Nov 16 07:06:32 CST 2026
