Home » Audio » Speaker » needles type array or full tweeter line array
needles type array or full tweeter line array [message #22892] Fri, 16 December 2005 03:05 Go to next message
Exipnos is currently offline  Exipnos
Hi there,
I'm thinking of building a full 7.1 system using identical line arrays across all speakers. This will be used in a dedicated home theatre room 15feet wide and 23feet long. The room will have 2 rows of seating. Now to the question.
I understand that using a full line of tweeters will help when moving around in a room and getting good sound either sitting or standing. But is this necessary in a dedicated HT where you will be seated all the time? Would needles type line arrays be good in this situation? Are there any other benefits of going with a full line of tweeter for my situation?
Thanks for you help.
Re: needles type array or full tweeter line array [message #22894 is a reply to message #22892] Sat, 17 December 2005 10:51 Go to previous message
Stephen Erickson is currently offline  Stephen Erickson
Everything I've read says ribbon tweets have very little vertical dispersion, so if using a single tweeter maybe use something besides ribbon?
Previous Topic: 3dB per octave dropoff?
Next Topic: best driver for voigt pipes
Current Time: Wed Nov 04 23:15:27 CST 2026
