Home » Audio » Speaker » horn for HF?
horn for HF? [message #22658] Sun, 12 June 2005 12:38 Go to next message
taylor is currently offline  taylor
I almost have my NSB enclosures done. I built 4, 8 driver columns so I can either stack them or use them separately or put a single tweeter in the middle. Ive decided not to use the Onkyo tweeters I bought. What I would like to do is use an Altec 811B in the middle of 16 drivers. Any reason this wouldnt work? The horn is taller than a normal tweeter so the 8th and 9th woofer will be a foot apart.
Bass will be provided by two Autotubas BTW.
taylor
Re: horn for HF? [message #22659 is a reply to message #22658] Mon, 13 June 2005 00:57 Go to previous message
Anonymous
Should work well.
Post pics.
Previous Topic: thanks for the info and help
Next Topic: Geddes shoots, he scores!!!
Current Time: Mon Oct 19 11:40:08 CDT 2026
