Home » Audio » Speaker » Short Line Array
Short Line Array [message #22483] Mon, 14 February 2005 13:41 Go to next message
DVD is currently offline  DVD
Is It possible to build a short line Array and still get a reasonable vertical dispertion?
What is the vertical dispersion characteristics of a line array vs line length?
Is it possible to use four 6.5 inch drivers and get approximately 3 to 4 foot dispertion window at 12+ feet?
Based on Dr. Griffin's paper I think it should be possible to do this allthough it will be in far field. According to Dr. Griffin's paper, four 6.5 driver should go far field at approx 6 ft @ 2KHz and then the beam should start to diverge. two 5 inch long ribbons on 6 inch centers, with acceptable vertical dispertion angle of 10 deg. included, should provide an acceptable vert. winddow at 12+ ft.
What have I done wrong? Four higher quality mid/bass drivers and two ribbon tweeter might be a littel less expencive and easer to build than a 10 driver 6ft array. Granted it would be Farfield, but it's all about tradeoffs is it not?
My short stack [message #22484 is a reply to message #22483] Mon, 14 February 2005 22:00 Go to previous message
lcholke is currently offline  lcholke
Hi dvd,
My short 4 stack "arrays" tend to sound like a point source in far field. The good thing is the efficiency is better than the single driver. They did not use ribbons. Try making a 16 driver array with the PE $.67 drivers to get the nearfield sound. You may like it and then save up for more of the better drivers. You will have a closer idea of the tradeoffs you are making.
-Linc
Previous Topic: hold a listening meet
Next Topic: Stacked "Mini Planers"
Current Time: Sun Nov 01 05:29:47 CST 2026
