Home » Audio » Speaker » Dumb question of the day..What's an NSB?
Dumb question of the day..What's an NSB? [message #22442] Thu, 20 January 2005 17:19 Go to next message
flacoman is currently offline  flacoman
I'm guessing this is a midwoofer of some sort , if there's some data out there i'd like to take a peek too.
TIA
Jorge
Re: Dumb question of the day..What's an NSB? [message #22443 is a reply to message #22442] Thu, 20 January 2005 20:04 Go to previous messageGo to next message
cmanning is currently offline  cmanning
NSB? It's fuel for the line array revolution. No Stinkin' Badges -NSB, refering to it's lack of any identification.
There a little pricey, but good drivers generally are.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=269-568
"They're a little pricey, but good drivers generally are." [message #22444 is a reply to message #22443] Thu, 20 January 2005 22:52 Go to previous messageGo to next message
Dumb question of the day..What's an NSB? [message #22445 is a reply to message #22443] Fri, 21 January 2005 04:21 Go to previous messageGo to next message
Ahhh. Those were the ones i was thinking of mass-loading. 24 in a line with Fs pulled down to 80 or so , open baffle. I'm thinking of the little Dayton tweeters to go with them ,crossed at about 5khz or so.
Thoughts? Suggestions?
TIA
Jorge
lowering fs [message #22446 is a reply to message #22445] Fri, 21 January 2005 09:14 Go to previous messageGo to next message
lcholke is currently offline  lcholke
Another way is to remove some (50%) of the spider. Not adding mass is better for speed and effency. I did this and the driver went lower. The power handeling is lower since the x max is reached sooner. But the driver sound breakes up before this happens. I have a 16/ side array. The only thing I did to the drivers I am using was remove the dust cap and add a plug.
-Linc
Surround Processor Q [message #22447 is a reply to message #22446] Fri, 21 January 2005 09:47 Go to previous messageGo to next message
Phase plug? Do tell ! I wanted to coat the cone to deaden the high freqency breakup.
Mislabeled header previous message -oops [message #22448 is a reply to message #22447] Fri, 21 January 2005 09:48 Go to previous messageGo to next message
I was looking at another forum ....oopsie
Re: Surround Processor Q [message #22449 is a reply to message #22447] Fri, 21 January 2005 12:47 Go to previous message
Nothing fancy. Removing the dust cap does lower the high peak without a 1st order coil in the signal path. The plug makes the sound clearer. I was listening this way for a few months. I have a coil at 3.3khz now. Last week I removed the plugs and the sound was not as clear. They are back in now.
1) cut the cap off with a knife
2) cut dowels .75" dia x 3" long on a table saw
I thought that the length would let the wave stabelize before the collapse at the end of the dowel. You may be able to make them shorter with a cone taper like the Audex ones. A lathe would help.
3) remove the burrs
4) place 3 small balls of rope caulk on the end of the dowel and press in place
-Linc
Previous Topic: fostex speakers in Japan
Next Topic: Anyone familliar with "Loud Speaker Builder / G-Audio"
Current Time: Tue Nov 03 19:33:20 CST 2026
