Home » Audio » Speaker » Array Angle
Array Angle [message #22406] Tue, 21 December 2004 03:53 Go to next message
Zene Gillette is currently offline  Zene Gillette
Hi ... If I angle a focused array so the speaker is off axis for better speaker response the focal point (which is crital in focused arrays)will either be in front or behind the listening position. Can there be a balance of response to focal point? Sorry Jim I cannot make the panel flat. Zene
Re: Array Angle [message #22412 is a reply to message #22406] Wed, 22 December 2004 18:43 Go to previous message
lcholke is currently offline  lcholke
Hi Zene,
My array looses the highs and the immageing as I move off the focus point. Are you using tweeters also? Perhaps you can have a shorter tweeter array that is in "nearfield" at the listening point.
Any pics yet of your towers?
Hope this helps..
-Linc
Previous Topic: Good link to T/S for Pro Drivers - Some rare stuff
Next Topic: Can I get some feedback on this design???
Current Time: Sun Nov 01 07:30:25 CST 2026
