Home » Audio » Speaker » Line array's
Line array's [message #22269] Thu, 02 September 2004 20:13
clyde-69 is currently offline  clyde-69
I built a set of line array's using 20 Audax 3" APO8OGO full range drivers and 1 H26TG25-06 horn loaded tweeter per cabnet, The sound coming from them is nice, but I would like it to be much better.
The cabnets are 5" wide, 8" deep (sides angled at about 15 degree's), & 72" tall open back. I plan to rebuild them using the same 20 3" Audax drivers and 4 PT2 plannar's from parts express. Any info that I could get would be great;
Some one that will build the crossovers even if I already have the drivers
Cabnet options
I also would like some input on a center channel and 2 surrounds using the same drivers.
I am a little slow on electronics, But I have a full wokshop with every woodworking tool avalable.
I am running 2- MK2 12" sealed 2.4 cu.ft. subs for the low end.
Thanks in advance for any info, Clyde
Previous Topic: Experiences with Jordan JX53 or Bandor 50 mm in line array?
Next Topic: Tang Band drivers
Current Time: Sat Oct 24 22:02:50 CDT 2026
