Home » Audio » Speaker » Bill Fitzmaurice, How's your Line Array hybrid coming along?
Bill Fitzmaurice, How's your Line Array hybrid coming along? [message #22234] Thu, 19 August 2004 14:58 Go to next message
lon is currently offline  lon
Hello Bill,
I don't check out the Line array discussion often enough.
You had a *pic* someplace on here for a line array
hybrid. Is that going to be in an _audioXpress_
any time soon?
I noticed in a posted *pic* you were using those Pioneer
4 inchers. Those are now about half price at $.49 each
and I am thinking on splurging for about 8 of them.
But they will be just be clutter if I don't have a good use
for them.
Will the design be available from your website?
Thanks and I hope you are well.
lon@athenet.net
Re: Bill Fitzmaurice, How's your Line Array hybrid coming along? [message #22235 is a reply to message #22234] Fri, 20 August 2004 08:26 Go to previous messageGo to next message
The article is at the publisher, so it will be out within a few months, after which it will go on my site. I used 8 drivers per side at 4 ohms; if you want to stay at 8 ohms go either 9 or 16 drivers per box. I wouldn't go less than 8 drivers per box. It does need to crossover to tweeters at 6kHz, so stock up on some of those closeout Onkyos too, at a 1.5 to 1 ratio with the woofers. I'm using my arrays along with a Tuba 18 sub, crossed at 80 Hz; the Tuba 18 will actually appear before the line array does.
Re: Bill Fitzmaurice, How's your Line Array hybrid coming along? [message #22236 is a reply to message #22235] Fri, 20 August 2004 13:05 Go to previous messageGo to next message
Do you use the 70 cent Onkyos or the 40 cent ones?
I got my 16 Pioneers so far, striking while the fire
is hot, so to speak. Shipping was more than the
merchandise.
Some specials they just run for a week, so I figured
I should get the order in today.
Re: Bill Fitzmaurice, How's your Line Array hybrid coming along? [message #22237 is a reply to message #22236] Fri, 20 August 2004 15:07 Go to previous messageGo to next message
I used the ones with the coax mounting post; I chopped the posts off on a bandsaw. Get a dozen per box to match with 8 woofers per box.
Re: Bill Fitzmaurice, How's your Line Array hybrid coming along? [message #22238 is a reply to message #22237] Fri, 20 August 2004 19:19 Go to previous message
These may turn into Winter projects for me.
So I didn't by any 'accessories' this trip in.
I'm wondering how these give-aways will sound for a test
in my PVC Boomtoobz.
Previous Topic: questions on array wiring and such....
Next Topic: Horns / Arrays
Current Time: Wed Nov 04 02:06:11 CST 2026
