Home » Audio » Speaker » ex2- to dx2
ex2- to dx2 [message #22050] Wed, 31 December 2008 16:41 Go to next message
Wayne, Bob called it "the basket" as I remember his saying it. It did cover the magnet and it has several 1-1/2" circular holes all around the edge with foam in the holes. The reason I refrained from removing it was I just didn't see how as it looked solid ---last nite when I revisited this basket there was a warning label that was very small stating that removal kills the warranty. I ran a razor knife all around that seam and then just pulled it off--there was a soft rubber seal binding this basket/cover --- Nevertheless I can assure you the sound from these speaker has improved at least to me, a lot...with that cover the image was not there, the sound over all was dead, especially the top end. Now it has that bright crisp mid range with real top end....and some decent bass---it is what I would call "Lowther Bass" not killer deep but solid...last nite I got a bit of the holiday happys going so I started trying different amps to see what differences I could deduce. the lineup was my Pilot 240 intergrated, A-30 fisher monos, the 2A3 custom (Akito design?) the 2A3 was hardly enough power but sounder thin or dry compared to the EL84's I liked both very much....I am building a sachiko "horn" for the 2A3 as many others say that will match up well-- I have a 6L6 (4 watts in pentode) to try out tonite
Re: ex2- to dx2 [message #22053 is a reply to message #22050] Thu, 01 January 2009 12:15 Go to previous message
I see now. Bob posted photos of the difference between the two speakers here.
Previous Topic: DCA 4 Zigmahornets
Next Topic: driver tweak to King BR box
Current Time: Wed May 01 16:58:30 CDT 2024
