Home » Audio » Speaker » Void Filling Foam?
Void Filling Foam? [message #21556] Sat, 03 June 2006 16:18 Go to next message
Skip is currently offline  Skip
I'm finishing a pair of Lowther Medallion II cabinets, which have
moderately large voids in the upper and lower backs of the cabs.
What kind of squirt/pour-in foam should I use here. It should expand
a lot, and yet not exert a lot of pressure on the ply panels. I don't
think it needs to be dense.
Your thoughts are most welcome.
Thanks,
Skip
Re: Void Filling Foam? [message #21557 is a reply to message #21556] Sat, 03 June 2006 22:12 Go to previous messageGo to next message
Scorey is currently offline  Scorey
This past winter I used some sealing foam from Dow Chemical that I bought at Home Depot called "Great Stuff." Worked real well, sealed real well and was sandable to boot.
Re: Void Filling Foam? [message #21559 is a reply to message #21557] Sun, 04 June 2006 11:29 Go to previous messageGo to next message
Be careful when filling. It expands enough that it will easily split the wood if you overfill.
Re: Void Filling Foam? [message #21561 is a reply to message #21559] Sun, 04 June 2006 19:22 Go to previous messageGo to next message
Thanks for the info. I looked at Great Stuff on the
product web site. I sounds like you would want put a small
amount into the speaker, let it cure and then add some more.
Sounds like you get a better cure, and avoid over pressuring
the wood.
Skip
Re: Void Filling Foam? [message #21563 is a reply to message #21561] Mon, 05 June 2006 05:44 Go to previous messageGo to next message
gfederys is currently offline  gfederys
Per recommendation on this forum, I just filled voids on a pair of Loather Fidellio's with "Great Stuff" for "Windows and Doors" from Dow. This one doesn't expand as severly as some of the others and is guarenteed NOT to bend the frames of windows and doors. My cabinets were already built, so I drilled 2 5/8 inch hole, one to spray and one for viewing. It worked great, just follow the directions on the can. After it cured, the cabinets didn't ring as much when I did the "knock on wood" test.
Re: Void Filling Foam? [message #21566 is a reply to message #21561] Mon, 05 June 2006 09:45 Go to previous messageGo to next message
Hey Skip,
A bit of pressure on your panels is actually good. It pre-loads the cabinet to minimize resonance. But like you said, not so much that it splits the wood.
Thanks All [message #21570 is a reply to message #21556] Mon, 05 June 2006 19:25 Go to previous message
I've gotten a lot of good advice including an email
waring from Ed Schilling of the HorneShoppe. He pointed
out that there can be a lot of splatter from Great Stuff,
splatter that can do serious harm to an eyeball. I
appreciate the help.
Skip
Previous Topic: GPAF Treasure
Next Topic: Mounting an 811 horn
Current Time: Sun May 19 15:47:05 CDT 2024
