Home » Audio » Speaker » Fostex FE206 in DBR
Fostex FE206 in DBR [message #21063] Wed, 13 July 2005 09:17 Go to next message
campe is currently offline  campe
Has anyone tried the FE206Es in a Double Bass Reflex cabinet?
I was thinking of a two chambers enclosure with a total volume around 70 lt ... I understood that this should help both in extending the frequency response and smoothing the peak at resonance.
I've seen that this approach is also suggested by Fostex for the 207, but I was not able to find on the net a similar design applied to the 206, so: where are the hidden problems (if any ) and/or pitfalls to avoid?
Any suggestion would be appreciated
Regards
Francesco
Re: Fostex FE206 in DBR [message #21081 is a reply to message #21063] Sun, 24 July 2005 09:51 Go to previous message
Make the uppr chamber about 3.7 liters with a vent into the lower around 50% SD. Dont know about the lower chamber volume. I believe it can be established for the same driver parameters except base Vas about 4x the 206e.It works in my pressure/waveform sims but shows a 3 db dip around 120 hz with a lower chamber volume of 60 liters.
Note! this is new and an unexplored terroritory for this action.
ron
Previous Topic: Idea for alternative to power tapering
Next Topic: Array wiring
Current Time: Wed Nov 04 08:48:27 CST 2026
