Home » Audio » Speaker » tube amps and vibrations
tube amps and vibrations [message #20813] Mon, 11 April 2005 12:48 Go to next message
Peter Swartz is currently offline  Peter Swartz
How critical is it that a tube amp be located away from speaker vibrations? I'm considering a configuation that would cause my M500 tube amps to be next to my speakers. Should I be concerned? Thanks for you input. Thanks, Pete
Re: tube amps and vibrations [message #20814 is a reply to message #20813] Mon, 11 April 2005 13:04 Go to previous messageGo to next message
Some tubes are more microphonic than others. With power on and the speakers connected to the amp, tap on the tubes and see if they make a ringing sound in the speakers. That will help you decide how much affect you'll have from sound produced by your speakers.
Re: tube amps and vibrations [message #20822 is a reply to message #20813] Wed, 13 April 2005 12:46 Go to previous message
I jhave noticed differences in my tube amps, after putting them on gel eet, and moving them awy from vibration prone areas.
The bigger the tubes, the more the vibration I'd say (simplistically)
-akhilesh
Previous Topic: Fostex 6.5 vs. 8
Next Topic: My finished line array *pics*
Current Time: Fri Nov 06 05:08:18 CST 2026
