Home » Audio » Speaker » correction of high freq(206e in a Jeriko)
Resistor values to get [message #20718 is a reply to message #20716] Mon, 28 February 2005 14:38 Go to previous messageGo to next message
HI,
Just get a whole bunch of 1 ohm resistors, and then try setting them up in series or parallel.
-akhilesh
Re: Resistor values to get [message #20720 is a reply to message #20718] Tue, 01 March 2005 01:26 Go to previous messageGo to next message
Kane is currently offline  Kane
Hehe!
Ofcourse...
Thanks sir!
kane
Re: correction of high freq(206e in a Jeriko) [message #20724 is a reply to message #20703] Tue, 01 March 2005 13:12 Go to previous messageGo to next message
DanTheMan is currently offline  DanTheMan
Those speakers take a long time to "break in." If their not broken in already I wouldn't do anything to them. I just got back from Japan and a guy there said to give them 6 months of regular use before changing anything. If they are broke in, then I would check your filtering options. MHO
Re: correction of high freq(206e in a Jeriko) [message #20725 is a reply to message #20724] Tue, 01 March 2005 13:23 Go to previous messageGo to next message
Ok, maybe a good advice but i have problem with some kind of music as high female voices and "hard" strings. I think i may break down before the break in??? Beeing a total novice in this format(horn) i have read many places and been given the advice at this wonderful forum that the high freq will be dominating because of the construction. Anyway its useful to know the time taking to break in and you may have the right answer.
Thanks
Kane
The BSC circuit is easiy reversible [message #20726 is a reply to message #20725] Tue, 01 March 2005 16:00 Go to previous message
While they are "breaking in" you cna use the circuit, and then modify or remove comletely after the yare "broken in"
-akhilesh
Previous Topic: SFRD projects
Next Topic: Vott 210 and slot cars
Current Time: Mon Apr 29 01:25:34 CDT 2024
