Home » Audio » Speaker » Push-Pull horns
Re: Push-Pull horns [message #20326 is a reply to message #20324] Sun, 29 August 2004 15:47 Go to previous messageGo to next message
GM is currently offline  GM
With an uncorrected mass corner around 433Hz, this is way too high for me, so I guess it's a 'different strokes for different folks' situation.
FR tech forum gallery?
Anyway, if you plot out what I posted you'll see that until you get near the mouth of the full size horn, which you wouldn't since the cutoff would be at a much higher frequency, the expansion is conical enough that I'd bet dollars to donuts you couldn't hear the difference outdoors, much less in a typical room.
GM
Re: Push-Pull horns [message #20327 is a reply to message #20326] Sun, 29 August 2004 20:42 Go to previous messageGo to next message
Yea James has installed a section in the image galleries for tech pics and such.
Cant take that bet GM, the Doc has put me on a restricted diet, seems like my fats are too high.
ron
Re: Push-Pull horns [message #20328 is a reply to message #20327] Sun, 29 August 2004 22:16 Go to previous messageGo to next message
Hmm, I saw your horn dwgs, but didn't see any specs for them.
Understand the problem well, I've lost 30 lbs since I saw the Atla DIY2003 Meet pics. Still got another 25 to go though, ugh! Oh well, I enjoyed getting them, but as usual, payback is a !@#$%^.
GM
Re: Push-Pull horns [message #20333 is a reply to message #20328] Mon, 30 August 2004 16:57 Go to previous messageGo to next message
GM, go to the image gallery page there will be FR drivers ,diy ,horns and such. At the bottom of the page theres a section that says Technical, i believe i have the only image in there at present.
ron
(those rice cakes can be made eatable,just goop on lots of cream cheese and grape jelly)
Re: Push-Pull horns [message #20337 is a reply to message #20333] Tue, 31 August 2004 20:31 Go to previous message
Arg! Didn't scroll down far enough. I have the fonts set so large I have to scroll pretty far just to get to the bottom of the horns section. Anyway, the point I was trying to make is that if you draw a line between the throat and at the 42.8" point and built it that way, you would be hard pressed to hear the difference. Now if a slower flare rate is used such that this slow expansion went all the way out to 1/4WL before a rapid flare to the mouth, it will work just fine if it's a straight line, i.e. conical out to this point.
GM
PS - I prefer cinnamon and sugar syrup on my rice cakes. ;^)
Previous Topic: New: First Watt amplifiers by Nelson Pass
Next Topic: Line array with single ribbon tweeter
Current Time: Fri May 10 00:30:59 CDT 2024
