Home » Audio » Speaker » My next pipe dream: Voigt Pipe with Goldwood 8"
Re: My next pipe dream: Voigt Pipe with Goldwood 8" [message #20094 is a reply to message #20091] Fri, 11 June 2004 15:33 Go to previous messageGo to next message
GM is currently offline  GM
Correct, click the Voigt pipe link. I see you got it work. WRT Excel 'clones', I'm only familiar with Open Office, which works fine except macros? don't function.
BTW, since MJK's worksheets assume polyfil, if you input the values for a fiberglass fill it will predict an understuffed 'sinewave like' response. In reality, it will mimic the polyfil response since FG has greater density/ft^3.
GM
Re: My next pipe dream: Voigt Pipe with Goldwood 8" [message #20096 is a reply to message #20094] Fri, 11 June 2004 23:21 Go to previous messageGo to next message
lon is currently offline  lon
Erf. Yeah, what you said. :-)
I have been through reading a good amount of Martin's
site and looked at the designs but I have to depend on text
rather than formulas for any understanding.
I am also curious as to why the software by Augspurgher
that's available from _audioXpress_ is not explored or reviewed
in the forums. Hell, I have not even seen it reviewed by
_aX_ itself.
I will take a closer look at your work and come back with
q's in a bit. I used the spreadsheet a couple years back
but I even have to refamiliarize myself with the syntax.
Re: My next pipe dream: Voigt Pipe with Goldwood 8" [message #20098 is a reply to message #20096] Sat, 12 June 2004 05:57 Go to previous messageGo to next message
Hi Lon,
>> I am also curious as to why the software by Augspurger
>> reviewed in the forums.
We're all waiting for you to do it.
Seriously, I expect that program must be good. Augspurger has been involved with many fine projects.
Wayne
Re: My next pipe dream: Voigt Pipe with Goldwood 8" [message #20100 is a reply to message #20096] Sat, 12 June 2004 12:44 Go to previous messageGo to next message
I don't read any of the audio rags, so wasn't aware he had a program available beyond his AES published data. If Rick's Alpha TL concept is just Augspurgher's work rehashed, then as highly stuffed TL concepts go, it works well and makes a good first approximation for developing designs in MJK's worksheets. If he has a program and the results closely mirrors MJK's, then it should be a winner also.
GM
Augspurgher [Voigt Pipe with Goldwood 8"] [message #20101 is a reply to message #20100] Sat, 12 June 2004 15:45 Go to previous messageGo to next message
So would this be a chicken and egg thing or two completely
different birds?
?????? (nt) [message #20102 is a reply to message #20101] Sat, 12 June 2004 15:52 Go to previous messageGo to next message
Voigt Pipes [message #20138 is a reply to message #20072] Thu, 08 July 2004 08:47 Go to previous message
FredT300B is currently offline  FredT300B
I'm building a pair using the Fostex Fe166E drivers.
Pictures at http://fredt300b.smugmug.com/Hobbies
Previous Topic: Max Power Input into drivers
Next Topic: speaker cabinet plans
Current Time: Tue May 14 04:10:00 CDT 2024
